1990 98 Olds Regency Brougham System help
Assault
Hello,
Well I have decided to stick with my 1990 98 Oldsmobile Regency Brougham Here are the speaker sizes (stock), how do you think it is?
Dash 3.5"
Doors 5"
Rear 6x9
Here are the selections I have come down to minus an amp (suggestions are welcome)
Subwoofer
Dayton Audio RSS390HO-4 x1 (maybe 2 later on)
Hifonics Brutus BRZ15D4 x2
6x9 Rear
Focal 690CA1
Autotek ATX693T
5" to 4" for doors will make two plates
Focal 100KR2 4"
Diamond Audio HEX S400A
3.5 dash
Boston Acoustics SE35
Amp
unknown
My 85 Olds Delta 88 has 3.5's in the dash and I use the Boston coaxials off head unit power and 150 Hz bass blockers. I had to modify the mounting grilles to fit them but they're very nice. I used Infinity Reference 6X9's (6-7 years ago) but the CDT's are probably the choice today.
If you have 5.25's in your front doors consider yourself lucky. I had to add my own. This should be your main concentration as it's your front stage. You'll get much better midbass and impact from 5.25's than 4's.
That's up to you. The 3.5's in my dash keep blowing out - the sun heats them up through the windshield and the voice coils overheat with hardly any power. My main speakers in the doors are coaxially mounted components with a separate amp so I just removed the 3.5's altogether. If you put tweeters there just remember to keep the GM black mesh cloth - I think it helps block the sun.
The first thing I am getting on the car all around 30% tint, the ceramic reflective material. So that will greatly reduce the heat. I think I'll find some 5" speakers with tweeters, try them out in place of the 3.5 (replace with tweeters) if it sounds good then I'll stick with em, otherwise I'll put the tweeters on the frame and throw in the Boston 3.5's
as far as subs go i had two of the hifonics hifi 12's in a box tuned to 32hz and they were more than enough. i had a 94 olds 98
Great to hear, and when is there ever enough bass? Haha, don't happen to have any pictures of your set up do you?
Assault
Assault
U.S.A Illinois
Assault
