17 volts
dude u can only run dual 1ohm subs in 2ohms or .5ohms unless u r talking bout putting both subs on one amp which u said u r getting two of those amps
so that means u can run each one at 2ohms 3600rms per sub u r clueless
are the amps strappable if so wat power at what omhs do they do
even on 2krms it will be close for 4 guage u will need 0guage no matter wat
you are helpless
you are helpless
they are both going to be ran off 1 amp right now until i buy another
then run it at 4ohms because idk if the amp is stable at 1ohm
plus i know u dont have the electrical to back that up if its stable at 1ohm u r looking above
4krms
wat kind of electrical do u have right now including power wire
by the way u wont run those ma's at .5ohms unless u have alot of power for them and i know u dont
Tkitt21
Tkitt21
GreenWood, AR
SmurfyGotMojo
