jshak07
148.4 and climbing
the local dealer said the new nightshades come fully loaded so that they can take more power. How will a 15" nightshade handle a 3000d?
They are rated 1500 watts RMS so a blown coil is no longer covered by warranty at double that.So with a good front battery, a rear batt and good ground as long as i set the gains right I would be fine? THis set up void the warranty on the nightshade?
Indeed - he has done VERY well with his Nightshades.derrick is hookin me up with a 3 cu ft that can be double tuned to i believe 42 hz and 34.5 hz.. from what it seems like he is the man for the job and is the one to do the job right.
If you have an HO alternator one in the back should do nicely.a good front battery and would i need 1 or 2 powermaster d3100s?
If you are the type of guy that listens wide open all the time I'd upgrade that - if not you are okay.my stock alt is 150?
