15" Mojo's or what?
I used them all season last season in comp. and I did loudest score posted with two 12's 150.2 at the head. And two 15's did a 152 head and a 157 floor could have been louder but I got a great deal on them and could not pass it up. There is better for cheaper but they can get the job done. I am not a fan of the new MOJO's at all only ones I would have would be the older orange and black models.
Also, if you're looking to get off cheaper.
Pick up two Power Acoustik PA3000DB's, they'll do 2k rms for daily and are decent amps, you can find them used for like 230 each //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
How much space do you have inthat XB? Do not seal any of the subs mentioned, including the Mojos
Dont seal them? ok i would say educated guesstimation there is about 10 square footage to be used conmfortably for a box
I dont know about the rest of the amps from PA, but I use and have used the PA3000DB here lately. They're not the absolute best quality amps, but they're great on a budget. The PA3000DB si rated for 2300 rms at 1ohm, 14.4v. You'll get **** close to 2k out of them at 1ohm, they're built fairly sturdy to be such a cheap amp, and they work just fine.
I was just giving you a much cheaper option that would work, that's all.
Nightshades are beefy, you have tons of options. If you have 10 cubes roughly, then two ported 15's sounds like the way to go.
What is your budget? That will help tons in deciding bro.
Budget is gonna be around 2500 for the entire setup. (i am sure i will go over...
hu
front rear speakers
4 cahnnel amp
subs
sub amp
sound dampering
box
cables
knetics battery
Budget is gonna be around 2500 for the entire setup. (i am sure i will go over...hu
front rear speakers
4 cahnnel amp
subs
sub amp
sound dampering
box
cables
knetics battery
hu - 300
front - 250
rear - 120
4 channel amp - 200
subs - 500-600
sub amp - 300-400
sound dampering - 300
box - ?
cables - 200
battery - 200
Yai will go over 2500.
I just sent you a message VERY similar to what you just posted, haha
Anywho, yes you will be going over. Let me know if I can help, just PM me I generally dont take forever to respond.
Are you wanting Sound Quality that's loud, or just pure loud as balls sound?
Also, if you run 4k+ I highly suggest you run more than 1 extra battery.
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
935
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
964
chunky cumz
past due splooge
chunky cumz
in ya mouf
mystang
    May 12, 2024
Brendon Jenness
    May 11, 2024
