15" Kicker L7 in a house room
I finally have everything connected and I even made a video of it. It's a 15" L7 wired at 2 ohms in a huge box (don't know the specs of box). With a Hifonics amp pushing around 700-800 watts rms. All connect to a Pioneer Premier 860mp. This video doesn't nearly sound as good as it really sounds. So don't fooled by the video. This system hits really hard. But I might have to sell it maybe later on.
Why? Kicker L7 in an SPL box in the home...god
Car audio specific drivers aren't meant for the home environment and you can't assume the same type of box will translate over to the home...the transfer functions of the home and in the car are complete opposites.
455
947
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
alex3kicker
slater
    May 2, 2024
slater
    May 2, 2024
