15" ava died, time for rebirth (recone)
Rsx_03
LoW aNd sLoW
EDIT: false alarm, wierd, it was locked up, took it outa the box and it was fine //content.invisioncic.com/y282845/emoticons/wow.gif.23d729408e9177caa2a0ed6a2ba6588e.gif
maybe its "the one" //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
but theres still this nasty rattle inside it, took off the dust cap, nothing that i can see is wrong. the higher up in hz i go the worse it gets, sounds like a normal rattle in a car //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
not just any recone will fit any motor. And the finished product will not be the same as it was before and it won't be same as the sub the parts should be in. It may or may not be better/worse
im not sure if AA still makes recone kits for ava's, the Q is about the same, should i get that recone kit instead?
and for example if an xxx recone did fit, would it be able to handle the 1600 rms instead of the 800 rms of an ava
They have not joined. They are two seperate companies. FI will be building the subs for Ascendant but that is as far as it goes. They are still Ascendant and FI is still FI
lol yea saw ur fs thread, but if anything im wanting to go for more output, im going to recone mine and sell it try to go for soemthing with more power
Is it ported now? I went to sealed because ported was too much for me. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yea i really hardly bump but when i do i want my teeth to hurt, wanst quite makin my teeth hurt though
and false alarm its not blown wierd ... but there is this really nasty rattle inside it, the higher hz u go up the worse it gets. took off the dust cap, cant seem to find it.
yep im pretty sure i can sell my ava pretty fast, my friend goes to gainsville regularly so i can have him pick me up a BTL
then just add another dcx1000.1 + a battery
Fi bought AA! so all future AA stuff will be built to fi standards //content.invisioncic.com/y282845/emoticons/fro.gif.c695f1f814b01c4ad99fe7f8cccadd29.gif
It's not just the coil which determines how much wattage it can handle or how loud it will get.
What are you basing your statement off of that the Q and Ava are about the same? They are 2 different woofers completely.
Best bet would be to sell it and get a louder sub
yep um the ava turned out to be fine but there is still this rattle from the inside and its noticable in my hatch, probably not in a sedan. so im going to sell my sub and then probably get a 15 fi btl
ayone know about this rattle im talkin bout, i took off the dust cap, i still cant find where it is.
Rsx_03
LoW aNd sLoW
Rsx_03
miami
Rsx_03
