15" AA Mayhem D1 (needs some TLC)
  • 5
Fireitup
Alabama
1. Product:
Title tells all
2. Specs:
Ascendantaudio.com
3. Description/Condition:
I reconed this and when gluing the surround it pushed all the way out to the edge of basket making the gasket not fit. Pulled the surround back up to redo glue and tore the edges slighty in a couple of spots shown in picture. Would just need to be reglued and tears patch to be fully functional.(worked before i pulled the surround back) Holes are from me mounting it and actually running it for about 2 weeks before deciding to try and redo the glue before selling. Replaced the terminals with 4g terminals as well.
4. Price: :
200 + shipping
6. Pictures:
Would also like to add if you don't go buck wild with the patching on top all of it will be covered by the gasket.
I guess I asked for that when I declared myself a noob. I mean the interior side of the firewall which is heat shielded with Lizard Skin.
19
I hope it ended up helping someone in here. I was right there on the Morels, but didn't need em, so I dropped out earlier than I would have, I...
14
I think the easiest path would be an electronic x-over. You will control all the frequencies from one unit, making for a cleaner and simpler...
Problem resolved - Found a scrap Astra that was fitted with that same unit. Salvaged the Display and original plugs and wired it up on the dining...
Honestly I'd run an audio control DSP or a helix DA helix DSP but if you want to run a app with the DSP that's fine too it's fine too but the LC8...
982
Fireitup
Fireitup
Alabama
Fireitup
    May 24, 2024
