149.9 (Outlaw) with one 8" Sundown SA-8
Honestly ? You could put two in 1 cube ported but fitting the port in the box within reason would be almost impossible... due to that fact you generally need to go a bit bigger.
I'd suggest 1.75-2 cubes for the pair tuned @ 35 hz. With 2 cubes this would be 28 in^2 of port x 26.5" long (a single 6" aeroport would work but you may have to do part of it external).
nice,may have to downsize to these. will my sae 1200 be too much for daily?
Should be fine - just set the gain accordingly.
The 1200s are capable of 1500+ watts so you could potentially hurt them after long periods of play... but you would really have to be going to town on them.
cool may be a new christmas present from the wifey:)
We got it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
150.2 dB this time by sealing up the port panel and running the speaker wire out of a drilled hole (sealed with silicone) rather than out the port :
very nice. wonder what could be done foward firing,hmm
Sean's amp rack is in the way so it limits us a bit on that. If I had access to another CRX I'd try it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
Mookie
