tracyrick
Limited035
I'm going to set my gain using a DMM. But I need to know the ohms number. I've read all the tutorials and I'm still confused.
If my W62 is wired by default from the factory with a parallel connection it says it will be 2 ohms nominal impedance per speaker. This is a dual voice coil driver.
My 500/1 will connect directly to this sub. No bridging. I think this means it's 4 ohms.
So for figuring what gain to use with a DMM, what ohm should I use? I'm guessing this all adds up to 4 ohms?
