Sold 12" solo-baric L7 subs
assassyn
I have Two kicker L7's that I will sell or trade for some 18" subs
$200 ea
The Kicker Solo-Baric L7 woofers continue to be the best sub in their class. The patented square-woofer technology allows for 18% more cone, which translates to more bang for your buck compared to competing round subwoofers. All new for the 08/09 series is a redesigned and improved SoloKon one-piece, injection-molded cone with full-coverage back bracing that pushes more air and creates louder bass than ever before. The new beautiful look was inspired by the big brother SoloX series, and it's making everyone at Sonic go crazy as it's tougher looking and better-performing.
In addition to the SoloKon improvements, the new L7 woofers also provide a much easier installation. The solid pole piece allows more heat sink capabilities and perimeter venting is built into the spider landing unlike previous years. This also allows for a shallower installation as you no longer have to account for venting through the back of the magnet. To make things even easier on the installer, Kicker moved the binding post to the corners of the woofer allowing for an easier connection when running the subs in parallel or series.
Key Features:
* 12" Dual 4 ohm Solo-Baric L7 Series Subwoofer
* Power Handling:
o Peak: 1500 watts
o RMS: 750 watts
* Titanium deposit impregnated cone woofer with rolled outer edge
* Santoprene rubber surround
* Full coverage back bracing
* Poly-cotton semi-progressive spider
* Spiralead™ tinsel-lead technology
* Highly-efficient UniPlate™ pole-piece/back plate
* Heat-reducing T-cut top plate
* Solid pole piece
* Cast-aluminum basket
* Spring loaded terminals
* High-temp dual 4 ohms voice coil
* Frequency response: 20-100 Hz
* Sensitivity: 89 dB
mounting depth? thanks
6 11/16"
assassyn
assassyn
Michigan
SicAudio
