12" IA lethal injection build...HELP!
BZA
Bring the MF Rukkus
These are the dimensions and tuning I am looking for but I want to do 2 ports, one on each side. can anyone help me figure out how to divide the 2 ports and still achieve the same specs as the box I posted? any help would be appreciated!
if you split the port area in half, and keep the length the same, then you will achieve your goal. Dont forget to factor in the extra displacement from the additional port walls in your final dimensions. If you need a reworked design explaining all of this, just let me know.
-Robin
-Robin
The port length will have to be a little bit longer if using two ports instead of one. And with a 15.5"x2" port, which is already somewhat skinny, I definitely would not suggest splitting it into two even skinnier 15.5"x1" ports.
BZA
Bring the MF Rukkus
BZA
Sherman Oaks (So.Cal)
RAM_Designs
