12" aq hdc3 on aq 2200 giving a slight smell
The dual 1 copper coil version. Yes, its the same box but i added a spacer on it to convert the hole to a circle. Yes i know, thats a little ghetto. lol
Which basket do you have? Depending on that would change my suggestion for tuning and enclosure sizes a bit.
AQ's recommendation is 2.25ft3 with 36in2 of port area and tuned around 33hz
what would your suggestion be then for the newest basket then?
Considering the AQ recommendation is/was also my own I would stay close to that.
Newest version of the HDC(which you have) have larger spiders and lower FS. The excursion is also increased over last years model.
Im not sure if this is right but didnt aq recommend somewhere around 1.8 - 2.2 cu ft and tuned from 38-40 hz? Or did it change because of the newer designs? But like i said, I could be wrong.
The website needs to be updated which I never got around to while I was there. What I listed is for your version of the sub.
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
myjaja
