ok im not sure which subs to get...The Digital Design 2500A or the Audio Pulse Epic. Both are 12", and i will be needing 2 of these. I like both subs very much but the EPIC is 600 RMS as the 2500a is 750RMS. Right now i have a CANDENCE TXA-1000D MONO Amplifier. It is said that this amp can push out as much as 1300 watts @ 1 ohm. So i would be running the subs at one ohm. These would go into my jeep wrangler and i plan on building a ported subwoofer enclosure along with it. I plan on taking the rear seat out in the jeep to make enuf space for the enclosure to rest on. i will also be needing some ideas on how to build a good enclosure for TWO 1000-1500 rms watts subs, and will make the system sound "loud". if any1 wants to make any blueprints here are the demensions which the enclosure should fit.
LxWxH(in)=32x10-36x10-15
i would prefer at least 2cf for each sub, or 4cf.
Here are the urls to the specs on each:
DD2500A=
http://www.ddaudio.com/dd/caraudio/woofers.asp?series=2500a
AP EPIC =
http://www.audiopulse.com/products/subwoofer-drivers/epic/
dd2500a
audio pulse EPIC
also where do you think I may be able to purchase these subs? Ebay does not have them and i cant find out where? THX FOR REPLIES!
DD2500A=
AP EPIC =
dd2500a
audio pulse EPIC
