12’’ FI Q Dual 1
Q12 - Fi Car Audio Store
Dual 1 ohm
Cast basket
Wrap around gasket
Kraft pulp fiber reinforced cone
Single layer wide foam surround
Push terminals
Extra heavy lead wire
FEA optimized motor
3" diameter 4 layer coil
Single high grade magnet
Quad progressive spiders
High or low Qts motors
Optional Heli-cool system
And many other custom options
Q12
DUAL 1
Fs: 34.2 Hz | 33.9 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 7.63 | 7.69
Qes: .39 | .39
Qts: .37 | .37
Mms: 249g | 253g
Cms: 0.87mm/N | 0.87mm/N
Sd: 481cm^2 | 481cm^2
Vas: 28.3 l | 28.3 l
Spl: 86.5dB 1W/1m | 86.3dB 1W/1m
Bl: 13.9 N/A | 19.65 N/A
Xmax: 28mm
Rms: 1500W
Sealed box: .8-1.5 High QTScuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
NO TRADES! $200 shipped anywhere in the continental US. If you’re local we can meet up or I will drive to you for a small fee.
Fresh Recone. Great condition 8/10 cosmetic 10/10 function. Great sub planned on using myself but never did. Sitting around so it needs to go. Has 2 very small scuffs on the surround and typical scratches on the motor.
12’’ FI Q Dual 1
Dual 1 ohm
Cast basket
Wrap around gasket
Push terminals
FEA optimized motor
Q12
DUAL 1
Qms: 7.63 | 7.69
Qes: .39 | .39
Qts: .37 | .37
Mms: 249g | 253g
Xmax: 28mm
Rms: 1500W
Sub OD: 12.500”
Cut ID: 11.125”
