1100 watts rms, and no sub to push...
gixxer9
I am looking for a 2-ohm final load sub that would love to live in a small sealed box (around 1.0 ft^3 net), be powered with a continuous 1100 watts, and have good SQ...
Must be able to fit in a box only 9 inches deep externally (7.5" internal) which is why I cannot use the Alpine type-X that I picked up...
The box must be this shallow because it needs to fit under the rear bench seat of my Silverado...
Thank you in advance for all opinions!
I think it's just under 7 inches.
EDIT: Yeah, according to the site it's 7" //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
linxuS, I would like to keep it under $400, but will consider all subs....
Hintzyboy, PM sent.
BlackMaxima and skmfkr, in fact, I am thinking about the fi Q, but have never heard one before...
cgrier, I will most likely be selling the Type-X because I'm going with an rl-p in my wife's car.
Thanks again for all your help.
The FI Q is a great sub. It's know for it's sound quality, but the output is still amazing me. I have a single 12", in a 2.3 cuF @ 31 hz. I'm throwing about 1350 RMS at it daily, and it takes it like a champ. Flexes the crab out of my truck. I can't listen to it at full volume for too long, makes my ears itch and ring lol.
You might have to go with a 10" for only 1.0 cubes sealed.
What amp is this??
Q12
DUAL 1 | DUAL 2
Fs: 028.4 Hz | 27.1 Hz
Re: 0.7 Ohms/coil | 1.4 Ohms/coil
Qms: 05.39 | 5.63
Qes: .49 | .48
Qts: .45 | .44
Mms: 211g | 231g
Cms: 0.15mm/N | 0.15mm/N
Sd: 481cm^2 | 481cm^2
Vas: 48.3 l | 48.3 l
Spl: 85.4dB 1W/1m | 84.8dB 1W/1m
Bl: 10.4 N/A | 15.1 N/A
Xmax: 27mm
Rms: 1000W
Sealed box: .8-1.5 cuft
Ported box: 1.8-2.5 cuft @ 28-33Hz
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: 7.000”
Displacement: 0.16cuft
gixxer9
gixxer9
Madison, WI
B_Campbell
