1000+ Watt Amplifiers
Originally posted by audiolife its in there i put it there myself or did you not "reach search" it? i used to rep the line also
If it is in there then my fault. my Bad
I Just told Gauntlet that most od his time was wasted
Because I know for a fact that Lanzar and amps like that do not get any where near 1000 watts
Holla back if u know different
You clearly don't know what you're talking about. Every Lanzar amp is not a VIBE series. Granted, I wouldn't buy one, but all 3 Lanzar amps listed put out more than 1000 watts. Please don't speak about "facts" when it's just things you've heard from other people.
I was wondering if you know of any 1000 watt amps that are designed for 5.5 volt preamp outputs. I spoke with JBL and they said that their amps were designed for a maximum of 4 volts. They said I could hook the amp up to my deck, but when I turn the deck up loud I may get clipping which will destroy my speakers. I know most decks are 4 volts and under .
Originally posted by joshpoints I was wondering if you know of any 1000 watt amps that are designed for 5.5 volt preamp outputs. I spoke with JBL and they said that their amps were designed for a maximum of 4 volts. They said I could hook the amp up to my deck, but when I turn the deck up loud I may get clipping which will destroy my speakers. I know most decks are 4 volts and under .
true.
just don't get pass the point where the headunit makes more than 4v.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by joshpoints I thought headunits put out whatever voltage they say the whole time.
if that was the case..we'd only have 1 volume then. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i see you guys listed the prices which is very helpful...but any ideas with 1000w amps are the most cost efficient and power efficient? Im looking for somethin thats cheap and has a small fuse rating...any ideas?
Gauntlet
bulletproof
Gauntlet
Cleveland, Ohio
MikeofTulsa
