1000.1 Amp or 1500.1 Amp powering 3* 10'' JL W3V2's??
if your talking about the subs their Dual-4 Ohm
if you're referring to the kicker amps, i would get the zx1500.1, wire the subs all in series than parrallel to the amp to get a final load of 2.66. You should see around 400-450 watts to each sub. If you get the zx1000.1 you should see around 300 watts per sub. I believe they should be able to handle the zx1500 if you set the gains correctly.
I would also make sure the box is set correctly, thats VERY important.
I didn't know boxes had settings. where should the box knob be located???
To the OP, you would need something that puts out ~900w at 2.66 ohms. So, you can get something that puts out ~1200 at 2 ohms (I think the kicker zx1500.1 puts out 1500 at 2 ohms), or you can something like the JL 1000/1, PG tantrum 1200.1, PG Xenon 1200.1, Alpine PDX 1000.1. All of those put out the same power from 1-4 ohms.
But there are a lot of options. You just have to decide how much you want to spend.
Personally, my vote goes to the PDX. They're great amps, take up very little space, and look really nice. Plus, if you decide to upgrade, you can get matching amps and just stack them up instead of taking up your whole trunk.
GTSLVR4
GTSLVR4
Poughkeepsie, NY
Hintzyboy
