10" ORION XTR's are IN,, THANKS!
  • Thread starter JimTJr
  • Replies 0
  • Views 407
JimTJr
Well I got them in finally. Wired them the way everyone said to. Only using the rear channel on the amp right now....in 4ohm configuration. Sounds pretty sweet. I may have too much room in the box though. Seems these needed about .75 cu ft. And I am closer to 1.0 Cu ft. Will this cause "Flutter" sort of? Or is the box not tight enough? (No leaks that I can tell,,,)
Just want to tweek it some now.... but it definitely makes that F-350 Crew Cab THUMP!
JimTJr
JimTJr
St. Louis, mo. Area
JimTJr
