I have a kicker Comp subwoofer In good working condition. Asking $30.00 Shipped OBO. Its 4ohm Single Coil.
Kicker 10" 300-Watt Comp-Series Subwoofer (05C104)
Polymineral Cone: This high-performance composite material features an Inverted Structural Dome (ISD™) that delivers added strength and reduces distortion.
Double stitched surround: The heavy-duty surround offers greater durability and prevents the cone from separating even under heavy usage.
300 Watts peak power: Rattle your windows and mirrors with plenty of hard-hitting bass.
Sturdy construction: Heavy-duty nickel-plated terminals and sleeved lead wires keep the power flowing and the two-piece vented pole piece and backplate keeps everything running smoothly by reducing heat and stress on the cone for better movement.
Enhanced Basket and Motor Assembly: The high-strength, steel basket offers a sturdy foundation to reduce distortion and improve bass output. The low-profile design makes it easy to install in just about any application.
Multiple installation options: This subwoofer can be used in a ported or sealed box. It can also be used in a free-air installation where it is mounted to a board that is attached to the rear deck or seat and uses the air in the trunk to produce sound.
