10" Kenwood small enclosureSubs... What kind of Box?
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 563
    Participant list
U
Unregistered
Guest
I have (2) kenwood 10" small enclosure subs, and it is recommended that they use .8 cu ft. of box space apiece. Will I have to alter the dimensions for a box if I put two subs in the same box (can i just make it 1.6 cu. ft, or will I have to make it larger?
sure you can make it 1.6 cu ft for 2 subs
just be sure to use a divider board between the 2 subs
so each sub will have a .8 cu ft air space each
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
467
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
736
Guest
SPLBassJunkie
    May 21, 2024
    May 20, 2024
