1 - Sundown SA-8 v1
Schnitz
I'm trying to design a vented enclosure for 1 Sundown SA-8 v1.
It will get 400w and is going in my 2001 BMW 530i. I want it to fire through the ski pass in the back seat (as seen below). The angle is 115 degrees. There are a couple holes in the rear deck lid to direct the vents through if that will help with sound quality.
My max dimensions are 32" wide x 15" tall x whatever depth necessary.
I modelled it in WinISD and got a 0.5 cu.ft box tuned to 32hz with a 3" diameter vent x 35" long (vent mach 0.8)
From all my reading this sub does well in a 1 cu.ft vented box. Did I model the box in WinISD wrong?
I tried getting RAM design a box for me to no avail.
I'm willing to pay $25 for a design that fits my needs.
1 cubic foot is a bit on the large side for these subs. I wouldn't go any larger than .75 cubic feet and feel free to save yourself some port length and tune at 35hz instead of 32. It will still get plenty low with a 35 hz tune.
I haven't finished it yet but I will be using PVC pipe.
I didn't go with the 2" for the same reason. Thought it would be more likely to whistle.
I'm going to do a small DIY flare on the PVC as well.
Schnitz
Schnitz
Toronto, ON
blobb454
