1. Product:
1 Sundown Nightshade 12" D1 custom
2. Specs:
Info from Jacob:
They have 3 prototype spiders (little lower Fs than the current models, these are slightly softer), plus double leads, new aluminum pole plugs, and the newest D1 coil with collar vents.
Specs from site should be close:
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA
3. Description/Condition:
Like new!! Nothing really wrong with them normal wear. Jacob did some testing with them, I have only used 2 the other two are still in the box from sundown.
4. Price: :
$350 shipped EACH.!.!. ONLY 1 LEFT OUT OF 4!!! HURRY UP IF YOU WANT ONE...
5. Pictures:
VC 1 reads 1.1
VC 2 reads 1.1
2. Specs:
Info from Jacob:
- Dual 2-ohm or Dual 1-ohm Voice Coils Available
- 3" Diameter 8-layer flat-wound Aluminum Wire Voice Coil
- High Temperature Aluminum Voice Coil Former
- 1500-Watts RMS Power Handling
- Over 2 inches peak to peak excursion
- Wide, triple-layer foam surrounds for high excursion
- Extremely strong paper cones w/ stiffening disc
- Thick poly dust caps
- Cast Aluminum 12-spoke basket with cooling vents
- Triple Stacked 1" x 9" magnet slugs for high motor strength
- MSRP - $629 USD
T/S D1 **:
RMS: 1500
Z: 2 ?
Re: 1.44 ?
Fs: 43 Hz
Qms: 6.83
Qes: 0.43
Qts: 0.40
VAS: 11.7 L
BL: 17.6 NA
4. Price: :
5. Pictures:
VC 1 reads 1.1
VC 2 reads 1.1
