1 ft^3 @ 32hz Build Log
rear wall not glued in get just sitting there with the angle brackets
I would have done more work but it seems that i have run out of screws //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif
Off to find the missing box!//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
so i found a new way of sinking in screws nice and deep. The standard countersink bit works just fine when your not gonna be running a round over bit at 12k rpm right over it...
I forgot to take a pic but its the hole bits that are used for drilling out door lock bolts and such, just a really tiny one. Ill get a pic later but thanks to the member that gave me the idea on hear earlier.
some higher quality pics to come later on. Those last one are from my palm centro, not to shabby for a camera phone i guess
now for the dirty glue pics //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hard to tell with the lines but that is a **** good tight bond right there!
What are old speaker boxes good for? filling with cement and being turned into weights =)
i dont like it either(carpet thing) you should of done it the way you did my first box(the seal one)what cars is it going in again?
Oh u mean tucking it into the slits?
That takes a good bit longer, It should have come out fine but i guess i messed with it to much... looks better after glue dried up and cant see it when its deep in the trunk anyway. Doesn't sound to bad for a single 10 though.
its going into a buddies mustang
twisztdauthorit
-db-
twisztdauthorit
Bakersfield, CA
Panic661
