1 dd9515 or 2 AQ HDC15s in 6 cubes. What do would be louder?
Right now i am running a small box for 2 15 cause its all the room i have, it is a six cube box with a common chamber tuned to 37 hz. My numbers as of now running 2 IA40.1's @ 1 ohm on my 2 AQHDC315 aluminum speakers is a 150.7 out of the trunk on the TL sealed up at 41hz legal, but i since i have a small box for 2 AQ's, if i were to reface my box and just do 1 DD9515 with 8kw and with 6 cubes and plenty of port, i forget my dimensions btw. Would it be louder do you think or do you just thinking im doing some crazy talk?//content.invisioncic.com/y282845/emoticons/waycrazy.gif.f4a380c3f94043939fd369defd9e6be2.gif
Discuss. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
my 9515g in 5cubes in a trunk wall tuned at 40hz burped 147.7Legal on my massive p3000.1 at .5ohm we clamped it at 3750watts rms...
this was in my monte carlo
my next system will me 2 hdc3 18s in 9cubes on prolly a Stetsom 4k2d or 2 saz-3000ds.. im my mag
get a D2 and run it 4ohm daly and 1ohm for burps, if u insist on doing 8kw.. thats what i did when i had d1's in my 9515g.. it was 2ohm daily (the 3000w rms of my p3000.1) and i burped at .5...
i just dont think 8k daily is good idea
Ok, so let's get passed to wattage. I run probably 4-5k daily I don't do 8-9k except when I hit thr tl, I don't have my amps pegged out max for daily obviously that would be stupid. But ehat my question is will 1 15 do better with the proper sized box or 2 15s crammed with too small of space?
your 2 aq's are not crammed.. 4cf per is rec. now ssince its a common chamber take you need 20% less airspace. so 20% of 8 is 1.6. you are .4 cf smaller than the rec. just give them more power
shakinghorizons
NorthCO
jamesw
