1 15 ported vs 2 10's ported vs 1 10 tline
dev199505
US
I currently have an HDS215 on about 850watts and love the way it sounds only down side is I lose all my space. I want to gain some space back with out losing volume. I've seen els1989 10" Tline and it it looks nice but his is in a truck with a lot less cabin space my setup is in a 1990 bronco 2. What do you guys think would be the best option? Would love to be able to keep my current amp infinity reference 1211a to save money. Amp is rated at 854w@4ohm 1300@2ohm not rated at 1ohm
Sent from my Z812 using Tapatalk
Thats a big jump down in cone area gotta have some realistic expectations of output if you gonna downsize without adding more power to a beefier smaller sub.
If I went with a 10 I would get a D4 and wire it to 2ohm so it would see the 1300watts. My 15 is wired to 4ohm right now
you still wont break even with the output, you can get kind of close to it but thats it. However you can get more bandwidth with a T line with an HDS 310
you still wont break even with the output, you can get kind of close but you can get more bandwidth with a T line with an HDS 310
HDS310 T-line at 1300watts? CSC recomended SA or American Bass xfl or tnt I was also thinking two HDS210s ported wired to 2ohm
dev199505
dev199505
US
Jeffdachef
