1 12 vs 2 12's
Better question woudl be why would you use 1000 watts of power to achive 140db's when you could do 143 by using a second woofer and same amp.. Even if it can take 1000 thermally who's to say it needs that much mechanically? Power compression even as you approach most speakers RMS does become a factor. 1000 watts when you coil begins to get hot actually becomes 750 as impedence is rising.. 2 woofers and you'd at least be using your amp to it's fullest potential again lol. There are alot of ways to look at it, but IMO if you can put less stress on the speakers, gain overall output, gain effeciency and have the room and money it's a no brainer. Don't get caught up with "rms" it's a marketing trick.
On an extreme level, compare say steve meades van to Gmonks old one. Gmonk had like 16 12's or somethign stupid. He also had less power or nearly the same as Meade, IIRC. On a meter they were probably somewhat close. However, in real life, it's not. Meade was pushign his 4 18's HARD.. His woofers woudl smoke within a few minutes of use. Gmonks putting like 200 watts per woofer for the same output. No burning coils, no torn spiders. He also had that kind of acoustic effeciency over a much broader range. Term labs lie too, 160 from 25-90hz is ALOT different than 160 in a 3hz range.
Price man. I'm not talking from a best from technical standpoint, but real world. Why buy 2 1000w subs when you can buy to 500w ones for a less price?
There are really too many factors to say it all comes down to what he finally decides to go with. It seems simple to me, because we don't know all the facts.
2 12"s>1 12"
I you care to actually listen to the setup on music, the same drivers on half the power each will sound better and get louder at the same time. Provided you have the space, it sounds like a win to me. No reason to beat the hell out of a sub running it near its limit unless you like tearing up your stuff.
I am comparing the 2 12 inch Treo TE's or the one 12 inch Treo SSp. Was thinking about going with 2 12 inch SSp's but I think 2000 rms would be a little overkill for my listening on a daily SQL driver. I want it to sound good and hit hard but I don't need it to rattle windows 3 blocks down the road. BTW these will be in fiberglass boxes sized to spec give or take .1 cu.ft.
Hope that helps clarify things.
Double the power and the cone area would theoretically be twice as loud (3db) so using that logic 1.5 db in a perfect world. Which we don't live in. There are also many other variables to consider.
The ssp is a far superior driver to the TE.. The SSp's are a high output sq sub, they will pretty much laugh at 1000rms each, but will get very loud...If you do not want to be that loud, I would port 1 SSi 12 opposed to 2 TE 12s
2 1000 on 1000 and if aint enough get another 1000 ...
buying two 500 cant go back and up the power . because the amp and sub combo would both need to got . unless a big 2k is already there and just not getting used. example
2 1k wrms subs
1 2k wrms amp
setup wire 2-4 ohms = 1kwrms then after breakin wired down to 1 ohm= 2k wrms
all done at once typically would cost more then a lower total watt setup
Buying two 500 cant go back and up the power . Because the amp and sub combo would both need to got . Unless a big 2k is already there and just not getting used. Example
2 1k wrms subs
1 2k wrms amp
wtf?//content.invisioncic.com/y282845/emoticons/*******.gif.a649d21efc0d1fd4890a6428166586c1.gif
You can't compare a daily driver that seats 6 to a big ass van that only seats 2. Nice try though.
I think my point went over your head. I'm comparing a setup that can play super loud for a few minutes to one that can do it all day, regardless of how they got there. Less power per woofer and increased cone are has it's advantages, regardless of whether they meter similarly. Lasty, bandwidth counts when playing music and a termlab wont' show you that. Just a single 12 ported wont' be "as loud" as 2 of the same subs sealed, at least not over a broad range. It may meter the same or higher,but it's a trade of bandwidth for effeciency. A second sub simply gains effeciency and keeps bandwidth constant. The only disadvantage to adding the second sub is cost. If you can afford it and fit it is the better option by far. Systems are more than the sum of their parts.... An array of $5 drivers can easily sound better and get louder than a pair of very expensive speakers. There is ALOT to be said for maximizing effeciency and reducing excursion and power relation distortion
Txhouse
Txhouse
Willis, Tx
T3mpest
