1 12 on 2000w verses 2 10s on 1200?
Yea was planning on down fire under the seat ported back unless there are any other better suggeations
4 8's forward fire! lol. Not sure you will have the depth needed for big mag subs downfire. You need clearance for the surround excursion when in downfire and then that only leaves you like 4 maybe 5 inches of depth max..
Will be doing seat lift bought so 2x2x1/4 square tubing today. Bringing it to my buddy's welding shop for him to cut a clean them up.
---------- Post added at 10:28 PM ---------- Previous post was at 10:27 PM ----------
I thought about 8s but worried about them getting low enough.
The right 8's in a proper box should get low fine
I have 2 10" xfls forward fire with aero ports in a 03 chevy ss . to down fire a sub in your truck is even harder. I didn't have to raise my seat. And I'm around 2.6 cu ft before displacement
I'm going with aero ports also so firing my ports forward along with speaker should be just as good as downfire port to the back?
sthib
sthib
la
sbarber82
