Sold 1/0 Big 3 Upgrade Kits Starting at $25!!!
scottiej
It's a shame I've got all this perfectly cut and terminated wire laying around and nobody is using it... here's how this works.
Pop your hood, and guestimate the lengths of the follow 3 cables:
1. Alt output to battery positive.
2. Battery negative to chassis.
3. Chassis to engine block.
An easy way to get a close measurement is to take a small piece of string or wire and lay it where the wire will go. Cut it with a pair of scissors to the length you need it to be. Do this once for each of the three cables above, and measure their length in inches.
Once you know the lengths you need, refer to the list at the bottom of this post and find the closest cable that will work for your installation. If you are in doubt, go with the next size up cable because you can always route the cable another way and tie it up out of the way. Some cars can be done for $25 or less plus a little bit of your time... some cars will take more.
Here are some pics...
Here is the list of available pieces...
Qty - Size (in.) - Color - Terminated - Price Ea.
28 - 7.25 - Yellow - 2 x 3/8" Ring with Red Jacket - $3.00
4 - 11 - Yellow - 2 x 3/8" Ring with Red Jacket - $5.00
11 - 7.25 - Silver - 2 x 3/8" Ring with Red Jacket - $3.00
3 - 24.5 - Silver - 2 x 3/8" Ring with Red Jacket - $6.00
13 - 24.5 - Silver - 2 x 3/8" Ring with Black Jacket - $6.00
3 - 28 - Silver - 2 x 3/8" Ring with Black Jacket - $7.00
18 - 34 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 38 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 40 - Silver - 2 x 3/8" Ring with Black Jacket - $10.00
5 - 42 - Silver - 2 x 3/8" Ring with Black Jacket - $10.50
8 - 44 - Silver - 2 x 3/8" Ring with Black Jacket - $11.00
8 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.50
3 - 64 - Silver - 2 x 3/8" Ring with Black Jacket - $16.00
5 - 73 - Silver - 2 x 3/8" Ring with Black Jacket - $18.25
27 - 41 - Silver - 1 x 3/8" Ring with Black Jacket - $10.25
21 - 50 - Silver - 1 x 3/8" Ring with Black Jacket - $12.50
1 - 21.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
5 - 24.5 - Red - 2 x 3/8" Ring with Red Jacket - $6.00
1 - 28 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
12 - 30 - Red - 2 x 3/8" Ring with Red Jacket - $7.00
3 - 32 - Red - 2 x 3/8" Ring with Red Jacket - $8.00
17 - 34 - Red - 2 x 3/8" Ring with Red Jacket - $9.00
5 - 42 - Red - 2 x 3/8" Ring with Red Jacket - $10.50
12 - 44 - Red - 2 x 3/8" Ring with Red Jacket - $11.00
3 - 48 - Red - 2 x 3/8" Ring with Red Jacket - $12.00
6 - 54 - Red - 2 x 3/8" Ring with Red Jacket - $13.50
3 - 64 - Red - 2 x 3/8" Ring with Red Jacket - $16.00
5 - 73 - Red - 2 x 3/8" Ring with Red Jacket - $18.25
4 - 38 - Red - 1 x 3/8" Ring with Red Jacket - $9.00
28 - 50 - Red - 1 x 3/8" Ring with Red Jacket - $12.50
1 - 64 - Red - N/A - $16.00
I will try to keep this list updated as frequently as possible so everyone will know what is remaining.
Updated List!
22 - 7.25 - Yellow - 2 x 3/8" Ring with Red Jacket - $3.00
1 - 34 - Silver - 2 x 3/8" Ring with Black Jacket - $9.00
1 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.50
1 - 64 - Silver - 2 x 3/8" Ring with Black Jacket - $16.00
2 - 73 - Silver - 2 x 3/8" Ring with Black Jacket - $18.25
25 - 41 - Silver - 1 x 3/8" Ring with Black Jacket - $10.25
11 - 34 - Red - 2 x 3/8" Ring with Red Jacket - $9.00
1 - 54 - Red - 2 x 3/8" Ring with Black Jacket - $13.50
5 - 38 - Red - 1 x 3/8" Ring with Red Jacket - $9.00
10 - 50 - Red - 1 x 3/8" Ring with Red Jacket - $12.50
How much for 1- 41 - Silver - 1 x 3/8" Ring with Black Jacket. But with 1 ring terminal at each end, and if u can 3 extra ring terminals shipped to 98531?
The 41" silver is $10.25... it only has one ring terminal as listed. I dont have anymore 1/0 crimps, but will sell these Tsunami Compression Fit terminals for $2.50ea.
With covers $3.50
Shipping is USPS flat rate... either $4.95 or $10.35 depending on what box I have to use.
how much for 2 of each of those? i need a lil bit more wire so i can put rear battery in different location
8 - 54 - Silver - 2 x 3/8" Ring with Black Jacket - $13.506 - 54 - Red - 2 x 3/8" Ring with Red Jacket - $13.50
I only have 1 of each left... will do $35 shipped for the pair. Can add some other lengths to it if you want. Just check the most recent updated for what is available.
Thanks!
scottiej
scottiej
Knoxville, TN
mojo212
