size depends on the fuse holder and the fuse needs to be at the battery. 100A would be fine. the sizes recommended above by mylows are also fine. note it's a parallel path to the stock power wire from the alt so each wire only sees roughly half of the alt output. personally, i prefer a fuse sized for the expected usage so it blows faster in case a short happens.
that makes sense. 0awg was clearly overkill //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I have only 1 amp(kicker zx1500.1) and with stock alt current will be low I think.
so 100A - 150A would be fine I guess?
Some people say fuse needs to be at alt... But fuse at the battery makes sense too. Ex: An accident and wire comes loose from alt and touches metal. If no fuse at the batt, battery=boom! right?
But what if wire is cut from half and touches metal. Alt will catch on fire?
