0-4 awg distro block
DaBaller504
Livin Loud In Da Blazer
my distro block has one 0 awg input, and 3 4 awg outputs
is it alrite to have 4 awg wire for the input and 2 4 awg outputs
or 1 4 awg input with a 4 and 8 awg output
would the current still be the same
i have a 4 awg input and 2 8 awg outputs on a distro right now, i am thinking of changing, which should I do?
if you are confused still reply and i'll explain better
thanks
u could get away with 4awg in, n 1 4awg out with another 1 8awg out.
however, runnin a 2awg in, with the two outputs above would be better.
my distro block has one 0 awg input, and 3 4 awg outputsis it alrite to have 4 awg wire for the input and 2 4 awg outputs
thanks
You always need the same input as output. Either that or the input should be larger. The ground should also be just as big as the input.
I think you should get 2 gauge in and run the 2 8gauge out with the 4 gauge that you are using for input now as another output.
By the way... where did you get that block from i have been looking for a 0input with 3,4gauge outputs for a while?
DaBaller504
DaBaller504
Westover, Pa
DaBaller504
