Both of these items are "Brand New In Box," and are discontinued (you can find them on eBay and other Online Car Audio stores but they will cost you much more than what I'm selling them for.) The SS65.2 6-1/2" Component System will cost $450 from woofersetc.com and around the same price on eBay. The SSMB6 6-1/2" Midbass Drivers will cost $70 from woofersetc.com and about $60 on eBay. Of course all these prices are without shipping included, so again this is where you will save with me.
These Components are superb, there output and sound quality are comparable to higher-end component sets from Dynaudio and Morel. Check the reviews all over the internet, they all agree that these components sound beautiful. You can tell because they aren't exactly cheap.
Description:
BRAND NEW, NEVER USED, NOT REFURBISHED, Kicker 04SS65.2 2-way Series Matched Component Speakers System
Specifications:
• 6-1/2" 2-Way Matched Component System
• Peak Power Handling: 200 watts
• RMS Power handling: 100 watts
• 3 Ohm Impedance
CROSSOVER
• System Optimized Two-Way Asymmetrical Passive Crossover Network Provides 24 dB High Pass and 12 dB Low Pass at 2.8Khz for seamless transition from midrange to tweeter
• Air Core Inductors Provides higher power handling with less ‘signal smear’ and magnetic saturation when compared to other ‘core’ type inductors
• Mylar Film Filter Capacitors Used in tweeter crossover section for smooth and extended high frequency response
• 3 Position Tweeter Attenuator Select from 0 dB, +1.5 dB or + 3.0 dB tweeter output level for level matching the tweeter to the midrange due to personal taste or mounting locations
• Zobel Impedance Compensation Provides more linear response across the operating range and prevents crossover point shift by correcting impedance rise
TWEETER
• DuPont® Tetoron® (Soft Dome) 30mm Diameter Tweeter Used to provide ultrawide frequency response. Excellent balance between high and low end frequency response
• Ferro-Fluid™ Cooled Voice Coil Enhances the thermal transfer from voice coil to the motor structure for higher power handling and decreased power compression
• Dual Neo Magnets In Tweeter Top and bottom magnets provide a reduction in overall tweeter size while increasing BL 22% over conventional designs (Patent Pending)
• Vented Inner Motor System The chamber under the tweeter dome is vented to the perimeter of the voice coil with machined channels in the motor structure to minimize dome distortion
• Sealed and Tuned Tweeter Enclosure Provides awesome control as well as smooth and extended upper mid/lower tweeter response from driver
• Foam Dispersion and Control Plug Used behind tweeter dome to control reflected energy and balance air pressure to the tweeter dome. Increases overall dome strength while in operation
• Copper Clad Aluminum Voice Coil Increases efficiency and thermal dissipation (power handling) of the tweeter
MIDRANGE
• Tri-Tech™ Cone with Röhm Rohacell® Foam Sandwhiched cone material of foam, poly and woven carbon fiber. Provides a very light yet very strong cone for extended frequency response and superior cone control over the midrange’s entire operating range
• T-cut Top Plate with Micro Plate™ Copper Cap Provides very linear and extended midrange response as well as increased efficiency and thermal dissipation (power handling). Micro Plate™ copper shorting cap reduces THD
• Edgewound Copper Clad Aluminum Ribbon Voice Coil Very efficient coil design that provides high coil winding density and increases thermal transfer from voice coil to the motor structure for higher power handling and decreased power compression
• Balanced Coil Construction The voice coil diameter and mass are engineered specifically to work with the driver system and provide an extremely linear and balanced response
• Variable Surround Thickness The surround thickness varies across its cross section to provide higher linearity and balance of the driver system, especially at higher excursions, when compared to conventional surround designs.
• Z-Wave™ Spider Design New spider design incorporating two complimentary shaped waves which provides better control over non-linear motion in the driver system. (Patent Pending)
• Comes in a protective case surrounded by blow-molded foam
• Speaker Size 6-1/2"
• Design 2-way Component System
• Peak Power Handling 200 watts
• RMS Power Handling 100 watts
• Sensitivity 87 dB
• Frequency Response 40 - 22000 Hz
• Impedance (per voice coil) 3 ohms
• Top Mount Depth 2-13/16"
• Bottom-mount depth N/A
• Cutout Dimensions 5-7/16"
Pics:
$175 shipped (Includes Shipping, Packaging, and Handling) to anywhere in the U.S.
Description:
BRAND NEW, NEVER USED, NOT REFURBISHED, Kicker 04SSMB6 Midbass Drivers
Sold
Terms & Conditions:
1.) PayPal -- vinni3pags@gmail.com
2.) I don't have any time for checking emails or going on AIM. So if you need to contact me, please just reply in this thread or simply send me a PM. I will respond ASAP.
3.) Price is negotiable. Please no trades. I prefer my online transactions to be smooth and hassle-free.
Thanks.
Description:
Specifications:
• 3 Ohm Impedance
CROSSOVER
TWEETER
MIDRANGE
• Sensitivity 87 dB
Pics:
Description:
Sold
Terms & Conditions:
Thanks.
