wiring amp
  1. J
    Correct wiring for my setup?
    So I have 2 kicker comp r 12" subs and each has dual 4 ohm voice coils wired in series. My amp is a pioneer gm-7200m. in the manual it says rms output at 4 ohms is 250w and at 2 ohms it is 360w. Each sub has an rms rating of 500 and a max of 1000. So by my interpritation (btw im pretty new to...
  2. F
    Amp question
    I'm replacing a diesel 440 watt 2 channel amp it has a 8 gauge power cord. I'm replacing with a xpr 540 dual do I use the same 8 gauge power or do I need to change because this amp is 1200 peak. I know this isn't the greatest amp but it was free and its just temp. its pushing 4 kickers 2 6.25 2...
  3. X
    Installation help.
    Hey guys, so i have this question about wiring and stuff. Components i have: Toxic TX1000 amplifier. datasheet: http://www2.produktinfo.conrad.com/datenblaetter/375000-399999/379195-an-01-en-Car_Power_Package_CPP_1000.pdf Mac Audio MP 225 BP Subwoofer with custom built box (bigger and better...
  4. I
    wiring and instalation helpp
    hi to all i need help wiring 4 speakers pioneer 4 oms and one sub woofer pioneer ts wx65 with 2 channel amp pioneer gm 552 so if someone can help me ill be great full ty
  5. MellowHype
    Wiring amp. Any advice?
    I basically need to re wire my amp, so my power and ground wire will be coming out, and put back in. do i need to disconnect the battery while doing this? is there a cirtain order the battery terminals need to come off/go back on?? Thanks in advance.
