wall build
  1. Psi_optima12
    6th order questions
    Hello everyone , I'm building m first wall and first 6th . currently in the process of building a 4 fi btl3 15's 6th order in my 1995 Chevy blazer 2 door v6. plan is to run 2 MD12k .5 ohm models wired at .5 on plenty of spim lithium ion 2 320 amp alts. besides tuning low which I'm tuning to...
  2. C
    Advanced design advice for 6th order?
    Hi all! I'm new here and looking for some advanced pointers/tips/advice on my 6th order wall build. vehicle: 2013 VW caddy cargo maxi Woofers: 8 excursion ssx 15 D2 (1500RMS each) Power: 2 excursion HXA20K at .5 ohms each (hopefully around 24KW RMS) Enclosure type: 6th order Rear tuning: 24hz...
  3. Ricky Garcia
    Extreme No Limit build
    Going to begin an Extreme NL build. The build will be in a 1985 Plymouth Voyager. looking for some advice on anything I should know what to do and what not to do. any questions or advice will be greatly appreciated. will be probably going with 2 15’s ,not exactly what amp we’re going to use...
