skar audio amplifier
  1. Chris brandon
    I need help picking either d2 or d4 SLD sundown 12
    I have a single behind the seat 12 ported box and I have a little cheap skar that’s going out so I want to upgrade to a sundown sld 12 but don’t know which would be better for my setup d2 or d4. I have skar 2000.1 amp which is rated at 2152 rms at 1 ohm 1400rms at 2 ohms and 800 at 4 ohms I...
  2. Zach Lawson
    Featured 2 4ohm subs to 1 ohm (1 channel amp)
    I have 2 1200watt skar audio subs. My buddy miswired them I believe when first installed and wired just a (+,-) from each subwoofer(4ohm) and ran it to the amp. It was played a total of an hour max closer to 45 min of actual play time. I wired them now correctly I believe 4ohm to a 1 ohm load...
  3. JahCOUSTEAUU
    Which subwoofer do I go with…? And what size??
    I have a couple vehicles that I’m workin on a “DiY” kinda build… I’m adding some bass to the stock system in my girls car… I’m tryin to decide… do I go with two 6.5 SKAR AUDIO EVL or just one 8” SKAR (both boxes will be ported) which setup is gonna give me more bass? The amp I’m using is the...
