Inconsistent Subwoofer
Emanuel Rodriguez
Hello guys I always have had this thing with my subwoofer where it is very inconsistent in the sound. Whenever I am driving the subwoofer sounds quiet, but whenever I stop or get to a red light it suddenly gets louder. I have a sundown sml-12 and it’s being powered by a cheap Amazon recoil 600 watt amp. The subwoofer is wired down to 2 ohm. Any help and tips would be greatly appreciated. Thanks
Hi Emanuel,
It sounds like you're experiencing a common issue with subwoofers related to the dynamics of the vehicle's electrical system and possibly the amplifier's performance. Here are some steps you can take to troubleshoot and potentially resolve the issue:
1. **Check Voltage Levels**: When you are driving, the engine's alternator is supplying power to various systems in your car, which might affect the voltage supplied to your amplifier. Use a multimeter to check the voltage at the amp while driving compared to when you are stationary. If the voltage drops significantly while driving, it could be causing the amp to underperform.
2. **Amplifier Quality**: You mentioned that you are using a cheap Amazon Recoil amp. Lower quality amplifiers can struggle to maintain consistent output under varying conditions. Consider investing in a higher-quality amplifier that can handle the demands of your subwoofer better.
3. **Grounding**: Ensure that your amplifier is grounded properly. A poor ground connection can lead to inconsistent power supply, which affects performance. Make sure the grounding point is clean, solid, and free from rust or paint.
4. **Wiring and Connections**: Inspect all wiring and connections between the battery, amplifier, and subwoofer. Look for any loose connections, frayed wires, or signs of wear that could impact performance. A secure and high-quality wiring setup is crucial for consistent sound.
5. **Gain Settings**: Check the gain settings on your amplifier. If the gain is set too high, it can cause distortion, especially at higher volumes. Conversely, if it's set too low, the subwoofer may not perform well at all times. Adjust the gain while listening and see if you can find a sweet spot.
6. **Subwoofer Enclosure**: Make sure that your subwoofer is in an appropriate enclosure (sealed or ported) that matches its specifications. An improperly sized or built enclosure can lead to poor performance.
7. **Test with Different Sources**: Sometimes, the issue can be with the audio source. Try playing different songs or using a different audio source to see if the problem persists.
8. **Check for Clipping**: When driving, if the amp is clipping (distorting the sound), it can cause the subwoofer to sound quieter. Make sure to listen at moderate levels to avoid this issue.
If you've checked all these suggestions and the problem persists, consider reaching out to a local car audio professional for a more in-depth diagnosis.
I hope this helps you troubleshoot the issue with your subwoofer! If anyone else has experienced this or has additional tips, please chime in.
Measure voltage at the amp when the car is moving.
I can just check that by putting a multimeter on the power and ground of the amp right?
Also the truck has a volt reader on the dash when I first start it up its at 14.4 but then it usually goes to just 14v. Then there has been other times where it drops down all the way to 13
If you're above 12v, you should be fine. I want to measure voltage at the amp, not at the battery or alternator, which is where truck gets its voltage reading.
evaluate everything would be a great idea...
No battery lights / alternator light coming on while driving?
Wouldn't hurt to also check your overall alternator output, just to educate yourself.
Start car & have meter on battery....
rev engine a few thousand rpm & you want to see 14 volts.
Not 12
Generally voltage gauges built into cars instrument clusters are nothing more than an idiot light, not accurate at all in most cases.
Not 12
No lights turn on while driving so thats good. Ill check alternator output when I can get a meter.
You can also try testing the amp by using a 3.5mm to RCA cable that connects your phone to the amp.
Emanuel Rodriguez
Emanuel Rodriguez
Texas
Old_Slapper
