I installed 4 6.5in mids and 2 3in tweeters, with an aftermarket amp, in my truck and they have a loud hiss when they are on even without any RCAs hooked up. I’ve tried grounding to the frame and cab. What else could I try to troubleshoot it
It sounds like you're experiencing noise issues, commonly referred to as "ground noise" or "hiss," which can be frustrating. Here are several troubleshooting steps you can take to help eliminate or reduce the hiss:
1. **Check Ground Connections**:
- Ensure that your ground connections are clean, tight, and made to bare metal. Sometimes, a poor ground can lead to noise issues. Consider using a multimeter to check the resistance of your ground.
2. **Power Wiring**:
- Make sure your power wire is not run parallel to the RCA cables. If they are, try rerouting them so they are separated. Ideally, power and signal wires should cross at 90-degree angles.
3. **RCA Cables**:
- Even though you mentioned there are no RCAs hooked up, sometimes the input stage of the amplifier can pick up interference. Check the quality of your RCA cables and ensure they are shielded. If you have spare cables, try swapping them out.
4. **Capacitor Installation**:
- If you are using a lot of power, consider installing a capacitor in your system. This can help smooth out the power supply and may reduce noise.
5. **Amplifier Settings**:
- Check the gain settings on your amplifier. If the gain is set too high, it can introduce noise. Lower the gain and see if it helps reduce the hiss.
6. **Noise Filters**:
- Consider installing a noise filter or ground loop isolator on the power or speaker wires. These devices can help eliminate unwanted noise.
7. **Check for Interference**:
- Look for potential sources of electrical interference, such as ignition systems or other electronic devices in your vehicle. Sometimes, relocating or shielding the amplifier can help.
8. **Test Components Individually**:
- If possible, test the components individually. Disconnect the amp and see if the hiss persists with just the speakers connected. This can help isolate where the noise is coming from.
9. **Check Speaker Wiring**:
- Ensure that the speaker wires are not damaged or frayed. Additionally, verify that the polarity is correct and that there are no short circuits.
If you've tried all these steps and the hiss persists, it may be worth consulting with a professional or considering a different amplifier, as some amplifiers may inherently have more noise than others.
Feel free to ask more questions, and hopefully, other members can chime in with additional suggestions or experiences!
