- Price
- $379
- Condition (1 worst - 10 best)
- 9
- Location
- Boise, ID
Price$379 Condition (1 worst - 10 best)9LocationBoise, ID
Price
$379.00 for the two sets
Boise, ID
This grouping consist of 1 pair of almost new Sony XS-692ES Mobile ES Series 6"x9" and one pair of almost new Sony XS-160ESMobile ES™ Series 6-1/2" 2-way car speakers!
9.5 because they are not brand new/open box
These are some of the best coaxial speakers you'll ever hear.
($229 for the set on their own)
Features & specs
The Sony XS-690ES replaces these items:
Product Research
Notes
Specifications: Sony's rated power spec for the XS-690ES is 90 watts (derived using IEC 60268-5 standards). In the manual they also list the CTA 2031 compliant RMS power as 110 watts. We've adopted the 110 watt RMS rating because CTA 2031 is the more common rating system.
($189 on their own)
Features & specs
The Sony XS-160ES replaces these items:
Product Research
Features
Mounting: These speakers can be easily mounted in a variety of 6¾" applications. Given the required cutout, they will also fit into the opening for a typical 6½" speaker (approximately 5" diameter cutout) but the screw hole pattern is larger than a standard 6½", so new holes would have to be drilled. Please enter your vehicle information to confirm fit.
Specification Note: Sony's rated power spec for the XS-160ES is 60 watts (derived using IEC 60268-5 standards). In the manual they also list the CTA 2031 compliant RMS power as 90 watts. We've adopted the 90 watt RMS rating because CTA 2031 is the more common rating system.
6 x 9's
6.5's
Price
Boise, ID
Features & specs
General | |
Speaker Size | 6X9 |
Driver Design | 2-way |
Woofer Design | Cone |
Woofer Material | MRC Aramid Fiber |
Woofer Surround | Rubber |
Midrange Design | --- |
Midrange Material | --- |
Tweeter Design | 1" Dome |
Tweeter Material | Synthetic Fiber |
Super Tweeter Design | --- |
Super Tweeter Material | --- |
Impedance (Ohms) | 4 |
Weather-resistant | No |
Grilles Included | Black, Steel mesh, Plastic frame |
Parts Warranty | 3 Years |
Labor Warranty | 3 Years |
Specifications | |
Sensitivity (1W at 1 meter) | 90 |
Sensitivity at 2.83 volts | N/A |
Frequency Response | 35 - 40k Hz |
Maximum RMS Wattage | 110 |
Peak Power Handling (Watts) | 330 |
Top-mount Depth (Inches) | 2 13/16 |
Bottom-mount Depth (Inches) | 3 1/8 |
Cutout Diameter or Length (inches) | 0 |
Mounting Height (Inches) | 0.481 |
Frame Width | 6.601 |
Frame Length | 9.345 |
Product Research
Notes
($189 on their own)
Features & specs
General | |
Speaker Size | 6 1/2 |
Tweeter Design | 20mm Dome |
Specifications | |
Sensitivity (1W at 1 meter) | 89 |
Frequency Response | 45 - 40k Hz |
Maximum RMS Wattage | 90 |
Peak Power Handling (Watts) | 270 |
Top-mount Depth (Inches) | 2 3/16 |
Bottom-mount Depth (Inches) | 2 1/2 |
Cutout Diameter or Length (inches) | 5 |
Mounting Height (Inches) | 0.484 |
Frame Width | 6.682 |
Frame Length | 6.682 |
Product Research
Features
6 x 9's
6.5's
- Was Photo Included
- Yes
- Was Note Included
- Yes
