Winners only.
So because it decreased 2% after increasing 27% the year before...Yay us?
Good question. If an increase gets complaints, then any decrease should get praise, yes?
Not only was the increase halted, it was reversed.
Or is it a fail because it is only 2%?
Would it be a fail if it increased by 2%?
You mentioned about “the past few years” of the feds flooding the money in, suggesting it’s a Biden issue and it’s bad.
The numbers show the money flooded in under Trump and is now moving back out (do to speak) under Biden.
Is the increase now good because it actually happened under Trump?
Instead of having to back up your words, you decide to ask me for a list of audio terms, and then say something nearly as dumb as “multiple outputs” on a mono amp.
There’s no negative output on an audio amplifier. The output is AC, not DC.
Are you asking about a negative feedback amp? I’m not familiar with any car amps that have negative feedback circuits.
I DO remember in the 80’s when Velodyne introduced their subs with an (?)accelerometer on the voicecoil to act as a feedback so the cone movement could be compared to the input signal, and corrected. Made for a very low distortion sub. Not car audio, but droolworthy.
As I mentioned to Spoke: If you’re going to pretend you are a wordsmith, that you know words better than the editors of the OED, and that everyone is stupid compared to your knowledge of English, then you sure as shit should walk the walk and use words correctly.
Don’t use words incorrectly and in a way that no one else uses them, and then pitch a fit when you get called out on it.
Just because YOU think “bridged” means two wires soldered to each other, does not mean the term is correct.
Just because YOU think a monoblock amp has multiple outputs since it has a terminal block on it, does not make it correct.
Language doesn’t work that way.
LOLOLOL
You are so easily led aren't you. So very predictable. Go get some coffee secretary man.
There you go assuming I meant biden...I purposely said past few years to to include trump...but no I'm not gonna praise a 2% drop...that's a joke number when put up against the increases the past few years...
Painted yourself into the failure corner again, and trying to spin it like you are some puppetmaster.
The only one you are fooling is you. Everyone else is either laughing at you or pitying you.
Don’t drop that Whopper when you deliver it, kid.
OK. So Trump screwed us over with the biggest increases in history, but Biden is a joke because his biggest decrease in history isn’t good enough.
That feels familiar. Kind of like when the economy collapsed under Bush, But Obama svcked when he didn’t fix it fast enough.
Selective criticism.
You see it as selective criticism because your a team politics individual...my point is the Fed govt fckd us and a 2% decrease isn't worth a damn let alone praise...I don't care what letter is after the name...bad policy is bad policy...
And Biden poured fuel on Trump's fire by decreasing the money supply that Trump increased.
Understood.
Has she done anything at all?
so this is what it has listed as her accomplishments . . .
she casted 19 tie breaking votes. lol Dont know why that is an accomplishment. . . but okie dokie
it says she made a trip to Guatemala and Mexico. thats super awesome
she served as acting president for one hour apparently. thats something
she went to Poland. Not a good visit, but its something she did.
guess its safe to say that some common ground we can all find is that Kamala is worthless
Slo_Ride
Regulator
Slo_Ride
ATLANTA
Buck
