2 channel amps to door speakers
The way he has it worded, it looked like he wants to run the sub off one channel and speakers on the other channel on a single 2 channel amp. When I installed my first amp ever, before internet existed, I had this same question in my head also, until I realized there was a big L and R on the amp like the back of my boom box had for the 2 detachable speakers. You’d have to run a system in “mono” instead of “stereo” to do this. Some of you aren’t old enough to remember running “mono” mode instead of “stereo” mode when the radio signal was bad. Forgotten technology.
sorry about the way i worded it
i see on all these sites that amps come in 2 channel ,3 channel and 4 channel
i was wondering if each channel could go to 1 speaker?
and if i got a 2 channel 1 could i direct 1 channel to the sub and have 1 for the door speakers
You would need a 3 or 4 channel to run 2 speakers and a sub. A 2 channel would only do the 2 door speakers.
So 1 amp for front and 1 amp for back, is that correct
Yes. One amp for doors and one for subs. But if you do not have the room, you can do what SlugButter said, a four channel amp. 2 front channels for the doors, and two rear channels for the sub/s. 3 channel amps tend to have better power and controls for the sub/s.
what if I wan this AMP with a P2 Rockford sub https://rockfordfosgate.com/products/details/p1000x5/ Had one shop quote me at 1100 for everything...
15
4K
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
191
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
885
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
173
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
590
JJ_64
JJ_64
St. Helena
pfft
    May 1, 2024
pfft
    May 1, 2024
