hooked rca to output instead of input.
  • 5
i didnt figure it out. i realized the mistake after the subs cut out (what there was from them.. musta been feedbackish **** goin on, ne wayz, the **** dont work now and i cant figure out what could be damaged from the improper audio signal...?
thanks for sharing, glad you figured it out
I am surprised that it went out, from you putting the RCAs into the wrong terminals. Did you check all your fuses? Does your amp turn-on? Is it in the protect-mode?
What brand and model # is your amplifier?
The output RCAs are just hooked up to it the input on most amplifiers.
I know JL has a preamp output filter and driving a signal in possibly would not be good however I do not know for sure as I have not been in one. I would imagine they would install diodes possibly especially with that price tag.
No make or model number on it? Do you have an exact picture of the rear and all its glory?
516
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
483
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
461
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
672
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
761
rockford86
rockford86
sicone22
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
