can the bass boost act as a crude subsonic filter if the amp doesnt have one?
realflow100
62
like i set the low pass filter first. then set the bass boost to just over half so until the frequency that outputs the most power is around 40 to 50hz with the gain all the way down and turn up the gain so that the voltage around port tuning is set right on the amp so the subs get the most power around that frequency range. so lower than that it'll drop off in frequency like a subsonic filter preventing the subs from bottoming out? since the bass boost is on it'll drop in output below 40hz or so and the subs wont bottom out below that?
if the amp doesnt have a subsonic filter can that work?
No, its not a cross over and the gain is not a volume knob, its a voltage matching pot to match the HU output as an amp can make full power with the gain off if the signal is hot enough.
so you are trying to create a really artificial and distorted 45hz peak in hopes of having less output down low?  I'd recommend just redoing your box so you can actually play a wider range of frequencies without reaching mechanical limits.  Losing cone control and subwoofer unloading is different from bottoming out... It takes a lot of fking power to bottom out a sub so use the correct term.
Yes, you'd effectively cut frequencies below the boost frequency, but you'd be cutting everything above it too, creating a sub that is useless outside of 40-60hz.
If your goal is bad sound quality I guess you're on the right track.
Generally, the objective is to have consistent output from ~30-80hz, if it will go lower that's a plus.
Unless you're tuned at 40hz not having a subsonic filter really isn't an issue.  Even if you are tuned that high, there's not that much music that spends a lot of time at ~30hz.
mine are definitely tuned to like 45 to 50hz or something really high. 25hz and below it gets quieter and stuff starts vibrating and jumping up and down a lot. and i want to cut down stuff below like 25hz  so its not vibrating stuff so much and my subs look like they are about to jump out of the box at 14hz. they arent bottoming out but they look close to it.
is there a way I could set up an EQ/filter subsonic filter on my pc instead if that will work better?
i just have one amp going to my subs and another amp going to my stereo speakers hooked up with a Y headphone cable splitter to hook both up seperately but in the same headphone output on the front of my pc
Maybe you should start over?.. you "modified" the enclosure to "30hz"
Had to repair a dustcap
Got some mechanical noises, and questionable repairs
Those ^^^^ are just the threads on THIS forum I know about.
I vote for the Wallsocket idea...  :clap:
Then you'll have to start over and if you're smart... get a low-tuned enclosure
i doubt you have any actual music that goes to 14 hz or 25hz literally 99% of the music out there has any material that goes under 30hz, very rare 28hz here and there.  Its probably low 30s and you dont even know the difference.  If you are just playing test tones... dont... just play music and movies normally.
How do you know your box tuning? Did you actually put all dimensions into an actual box calculator or are you just shitting all these numbers out of your ass?
I play all kinds of music some even have below subsonic frequencies bass i love you has some frequencies below 10hz and some other songs have super deep bass like 20hz violation and subsonic world and stuff have bass below 20hz and a song called 17 hurts
What ever happened to those "Terminators"?
OP is slinging advice on another forum, like a expert... guess those theories and expertise can't be held back...  :suicide:
I still vote for the wall socket idea
:scared:
realflow100
realflow100
realflow100
slater
    Oct 4, 2025
    Oct 4, 2025
