2 or 3 way cross-over?
  • 2
MrAli
Junior Member
Tehran
I have a Kenwood KMM-BT304 head unit. I do not know Which cross-over should i select in head unit? Now, its setting is in 2way by default and I have paired it with 4 coaxial 2way speakers (Focal RCX130) in front and rear doors.
I want to add an active (powered) subwoofer (JBL BassPro SL) to this gear and I confused which cross-over (2way or 3way) I should select in HU setting in this situation? please guide me. thx.
3 way is if your amplifying each speaker on a different frequency band (aka active crossovers). If your component speakers are running off a passive x-over, then select 2 way
sorry I do not get your idea. i am a newcomer here. let me explain more about my system: a Kenwood kmm-bt304+1 Sony xm-s400d amplifire (4 Chanel for 4 speakers)+4 Focal rcx130 (2way coaxial speakers) in doors+1 JBL active subwoofer.
which crossover should I select in such a system?
and if I remove active subwoofer, which crossover should I select?
ok, so the 3 way/2 way x-over thing is where the deck uses the 6 pre-outs for front/rear/sub for 2 way and front tweeters/front mids/sub for 3 way. # way is known as "active crossovers" or more traditionally "bi-amping". Car component speakers come with tweets, mids and a passive crossover, when running 3 way (aka active x-over, active network or bi-amping) the deck will separate out the frequencies for the tweeter and mid before the amplification happens thereby eliminating the passive x-over. Sound quality is immensely better in an active setup, but you lose the rear channel. Does that help?
Thank you so much. I get the idea. also the answer from Kenwood support which I received just now is similar to yours:
  • [SIZE=10pt]Thank you for contacting JVCKENWOOD Customer Support. In response to your inquiry, with your current setup and future upgrade, we recommend to use the default Crossover (2 way). 3 Way Crossover is only applicable if you have component speaker system (Front Preout for Tweeters, Rear Preout for Midrange, and Sub Preout for Subwoofers).[/SIZE]
right on. yeah, their answer is a tad wrong tho. theyre saying that if youre using a component set to use the 3 way crossover but a component set is usually connected to a passive crossover which is after the amplifier, but it sounds like you have the concept
My understanding from your answer and Kenwood ones simply is this: use 2way crossover when using only coaxials in doors or coaxials+sub. and use 3way when using components including tweeters+mids+sub.
Isn't it correct?!
Isn't it correct?!
Use 3 way when you're aplifying the tweeter on its own channel of the amp, same as the mid. 2 way when using component speakers on a passive crossover
Check out Focal. I believe they have direct replacements for many Toyota's...
Make sure they provide a warranty for theyre work and everything you buy.Ask to keep all the Boxes that every amp and speaker and sub comes in...
It depends on the brands they want to use. I would go with speakers first. If they sound great on radio only, then I would add the amp and sub...
MrAli
Junior Member
MrAli
Tehran
youdoofus
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
