Any chance it has a second or third set of rails that switch on when needed, resulting in the somewhat better efficiency? I like the cap idea, too. Any of these monster amps using ultracaps inside yet? Just throwing out ideas.
Their explanation is actually not very good. If the amp makes it before clipping... it makes it before clipping. Honestly in my opinion the only way to "Trick" the dyno is to use a shorter duration sine wave.... you could do a build track that would be a shorter amount of time and I theorize it would produce more power than the 10 second standard track.
