you dont see amps like this everyday...
There are two schools of thought about DF. One side thinks it's all important. The other thinks it's virtually useless and just a marketing thing.
The most simple way I can describe it is... it's essentially the internal resistance of the amp. And how much the amp "fights" the power returning from the sub. Higher DF = Lower resistance, less fighting. You'll hear people talk about "cone control".
The thing is... amplifiers have inherently low resistance anyway. AND the amp is just one of the components in the circuit that make up the system. The subwoofer coil being another HUGE component. Even if you had an amp with a DF of 1,000... by the time you wire it down to 1 ohm... that big ol' fancy impressive DF might be in the single digits on a Class D.
Better components have better tolerances and lower resistance. Same with build quality and the traces and all that little shit that goes into building a high quality amplifier. So higher quality amps just naturally have higher DF. They have higher DF *because* they're higher quality. They're not high quality because they have a higher DF. Does that make sense?
Have you ever heard Class A/B on subs? if you have, you know it "sounds" louder than comparable power of Class D. Or "cleaner" at least. Most will attribute this to DF. It's also the reason that wiring up to say... 2 ohms people get surprised how loud it still is even if they were running .5 before. Higher load, higher DF.
I can't go into detail about how DF specifically affects the TL score. or if A/B is actually louder than comparable Class D. But the anecdotal evidence is compelling. I reckon some (or a lot) of it may be the difference between high voltage and high current. But I have no concrete evidence one way or the other.
People should be doing more R&D on this topic if they aren't already.
Thank you very much for the information!
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
192
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
438
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
basswiigee
basswiigee
MICHIGAN
adulbrich
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
