xfl vs cvr New models
thats if given the proper enclosure size. OP is stuck in a small trunk. Smaller boxes will indeed impact output and need more power to reach proper potential.
That's assuming recommended enclosure size which is relatively unchanged from lower to higher RMS subs for the most part. Port area is the main thing that should change with power.
Motor force, MMS, and compliance determine efficiency. If the motor force is high, it overcomes the latter two. Motor force on larger RMS subwoofers tends to be higher, to a certain point. It's all dependent on the driver.
Jeff will never listen to that. I've tried for a year now.
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
I have 2 of them in around 2.5 cubes per sub, tuned to around low 30s Hz. I think.its tuned a little low. Really low frequencies hit thick and...
4
tyronekndrck
tyronekndrck
cincinnati oh
LosIsATool
