B BigRed98Ram 10+ year member Eats Fords 90 0 Chicago Il Apr 25, 2007 #1 Lets just say the amp puts out 800wrms at 2ohms and the sub is a dual 4ohm but wired for 8ohm what would happen...? Click to read more...
jmanpc 5,000+ posts CA.com Nostalgist. 16,929 4 Jacksonville, Fl Apr 25, 2007 #2 Why would you wire to 8 ohms? Theoretically, power would be 200w.
audiobahnuser18 5,000+ posts CarAudio.com Veteran 10,201 0 Mi Apr 25, 2007 #3 you want the sub wired up at the same ohm as the sub so example you have a 4ohm amp you want the sub wired up at 4ohms but it also depends on how u have the sub's wired to the speaker channels on the amp itself.
profundus-sanus 10+ year member CarAudio.com Veteran 3,009 0 wilmington, NC Apr 25, 2007 #4 well you would get significantly less power But also less thd and a larger damping factor which means better sq.
