2nd battery wiring question
Denial-
CarAudio.com Recruit
61
11
Pa
I have a 370 amp alt with the big 3 done and all my wiring is going back to a copper distribution block if you wanna call it that. Right now it just has my amp for my subs hooked up but im planning to attach the 4 channel for my other speakers shortly. My question is about a second battery can I just run that into the copper distribution block anywhere or does the second battery have to be ran before that with the main run of power wire going into the second battery and then wire the battery into the distribution block? I'll attach a picture of the copper distribution block just for visual help since I'm sure this was hard to understand.
Thank you guys for the help, sorry again if it was confusing to follow.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
I have not tried any Lith.Batteries yet. I am debating on that for Next years build out. deff considering
15
3K
Denial-
Denial-
Pa
Silicon oxide
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
