Which two 10's? Sealed box - Dodge Ram
  • 4
96TL
Hey all.
I've been out of the car stereo scene for a few years now. I'm looking to add some bass to my Dodge Ram. I've leaving the factory Alpine system and just adding two 10's under the rear bench. It's a lease and I don't want to mess with the door speakers. The NetAudio under bench box I ordered gives each sub 0.8 cu ft, with a max mounting depth of 7.5".
- At first I was thinking JL 10W6v3's, but they're overpriced IMO.
- IDMAX came to mind, but they're too deep. IDQs might not be loud enough for me.
- FI Qs I'm sure are nice. I had a BTL years ago that I loved. I'm not sure if I can feed them enough power though!
- Sundown SA10s aren't recommended in a sealed enclosure. I can't find much info on the new SD10s (don't feel like experimenting with them).
- DD Audio TS2510s look like they might work out. No experience with DD though.
Any other recommendations?
Thanks!
Definitely more on the SQ side. I don't need crazy SPL, especially since it'll just drown out the rest of the system anyway. The subs will be in the cab with me, so I want clean bass. Still loud though! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Loud just isn't really going to happen. But, that all depends on your definition of loud. The DD's are a good choice. Cdt's are also a good choice. Sd's are a good choice. Placement and box volume really hinder low end performance. Trucks are really hard to get to sound good. With the factory radio it should be a great improvement
I figured that. The bench muffling the subs can't be that great for output.
I could have went with a Fox box, which is vented (and louder). But I heard they're customer service is really bad. Also, not a fan of plastic boxes.
Very little room for subs in the truck. A lot of people like the type r 10 in these trucks. I haven't used them though. Center console boxes sound pretty good and have the ability to get low.
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
If you experience any air leakage from the screw holes.. adding Clear or the color of you choice of Silicone works just fine after a 24 hour cure...
10
Stereo Integrity hst12, only needs .6cuft after displacement. I have mine in a 15 inch double wall birch ply cube, .55cuft after displacement...
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement. Sealed will be .8-1.25. That said ported has the...
96TL
96TL
Brooklyn, NY USA
96TL
