New DD Sub with Rockford Amps in a sealed box
  • 3
connerprince
CarAudio.com Newbie
15
Irvine
Hey everyone, I recently bought and installed two Rockford amps, one 4 channel for the speakers, and one mono for the sub. I bought a 12" DD SL600 as well and have it in a sealed box because the ported box the shop offered were all massive. Is there anything else I might need? The shop did talk to be about the potential sound benefits of having it in a ported box but I couldn't find one that was small for a 12" sub, what're your thoughts?
The box is everything
Either have one custom made that fits your needs or if you even semi competent with a saw and a drill you can make one yourself
Its not all that hard
Its never going to sound as good as it could in a prefab box
Most ported boxes will be 1.75-2.5cubic feet of airspace. That's just a base requirement.
Sealed will be .8-1.25.
That said ported has the benefit of being tuned to your listening preferences and vehicle acoustics.
The sl600 while I'm not sure without modeling the speaker in a box program will likely benifit from a ported enclosure. That said in your given airspace a ported 8 or 2 ported 6.5s may give you better performance. Maybe even a ported 10.
That said sealed isn't a bad box method it just struggles in the lower octaves imho
roger that, just got one from sonic electronix for $189. thanks for the help
18
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
7
4K
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
180
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
345
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
435
connerprince
CarAudio.com Newbie
connerprince
Irvine
winkychevelle
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
