What settings for my Alpine 4 channel and Alpine Mono?
  • 2
Hoyta
Hello all!
I'm no sure of the complete specs on my amps, but one is a 75 x 4 alpine and a 300/1 alpine. I have MB quart reference components in the front, and MB quart reference coaxials in the rear(Old German ones). The sub is a shallow mount MB Quart 12" reference series (New Maxxsonics)
I have an older Kenwood head unit as well....
I'd like to know the best way to control the settings on these amps- The gain, the Bass EQ, and the LPass filter on the mono.
Hopefully these aren't foolish questions!
Thanks in advance for your help!
-Adam
For the mono, set bass at default position. Set gain to preouts voltage. Considering its an older HU, im going to assume that its between 1 and 2 volt. Check to be sure, but if thats the case, then right about 2 oclock setting is fine. LP filter, id say around 80, but thats all about preference. People typically go anywhere from 60-100 on that
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
585
The intention of the eq is to create a flat curve if you have peaks and nulls. If you are competing for sq, try to get the sound as flat as...
5
536
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
You are going to need to beef up your sub stage in that vehicle to get that kind of bass response. A good pair of American Bass XFL 10s or 12s or...
4
938
Hoyta
Hoyta
Edenton,NC
kr15
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
